Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Warning lights on dash light up under heavy acceleration
Old Nov 28, 2006 | 04:35 PM
jeffski1's Avatar
Default Warning lights on dash light up under heavy acceleration
Just bought a 2001 6-spd Allroad with 72,000 miles. Drove like a dream during the test drive. However, on drive home, I got into it a little more aggressively and some problems surfaced.
When accelerating hard, whether from a stop or doing a 60 to 80 mph pass in 6th gear, the engine seems to lose power above 4000rpms (surges as well) and four lights come on on the dash: ABS and Check Engine, a triangle with an arrow circling it (ESP I think), and a car icon with an up and down arrow in it (ride hieght?). Once I let up, the ABS and ESP lights go out, the check engine light sometimes goes out, and the car icon always stays on. They all reset when I turn off the car and start it back up. The car drives great when driven normal. No lights come. Even moderate acceleration is ok. It's only when I floor it does it seem to object.
Additional info, the car has an APR chip installed and I was running with 93 octane.
Old Nov 28, 2006 | 04:39 PM
techbod's Avatar
Default RE: Warning lights on dash light up under heavy acceleration
sounds like a power surge problem ( alternator ) APR chip they do cause some issues like this
Old Nov 29, 2006 | 02:17 AM
jeffski1's Avatar
Thanks. That is the sort of info that I was looking for. Do you know if there is a fix or update for the APR chip. I used to have a GAIC chip for my GTI amd it would surge as well.
However, I think there are bigger issues at work here. I have been doing some research and it sounds like a faulty ABS module might be part of the problem. I hope not because it sounds like an expensive part ($650 min), and that's just for the part, and if I can DIY.
Old Nov 2, 2007 | 01:03 PM
romberger02's Avatar
Did you ever find out what the problem was? I just had 4 new tires put on my car at a foreignauto shop.I had the tires mounted and balanced and then a 4 wheel alignment and then after a phone call was told I needed a new tie rod assemblyon the frontpassenger side because it wasfrozen. After paying over 800 for all of thisservice I picked my car up and drove down the road and aside from the steering wheel not being aligned with the tires, I had a real lag in power and the suspension light, ABS and ESP lights came on when I tried to accelerate. I didn't have this problem before I took it to the shop.Needless to say I phoned them and told them to expect me in a few minutes and then made a U turn and took it right back. They have had my car now for 3 days and still have no answers for me.
HELP!
2004 Audi Allroad / 2.7T
Old Nov 2, 2007 | 07:43 PM
auditech79's Avatar
Tell them to fix the alignment, the problem with the abs and brake light flashing is probably the abs control unit. They commonly go out and are VERY costly to replace.
Old Nov 18, 2007 | 06:28 PM
transientdirtbag's Avatar
If you haven't checked out www.modulemaster.com do that. I did their replacement in a 1999 A4 and my allroad has the same ABS module code. They are VERY quick with the turn around, and if memory serves correct, the new part with return shipping was $200 even...a hell of a deal when you look at complete replacement. Oh ya...it comes with a transferable 5 year warranty.
romberger02
Oct 28, 2024 05:56 PM
Michael Steven Torres
Sep 1, 2012 08:52 AM
B7 Models
Aug 31, 2012 10:33 AM
njtrackstar
Aug 14, 2007 10:59 PM
OptimoCynic
Jan 27, 2007 02:47 AM
