2008.5 2.0T How to remove engine cover?
Old Jul 30, 2009 | 12:10 AM
a3driver33's Avatar
Default 2008.5 2.0T How to remove engine cover?
Hi Guys,
I've got a 2008.5 A3 with the new 2.0T engine with the chain instead of a belt.
How does the engine cover come off? Looks much simpler than the old 2.0T cover but I can't see any screws or attachment points. Does it just pull off?
I just want to be able to remove the oil filter, which is blocked by the left lower corner of the cover. Is there anything else I need to know about changing the oil on this?
Thanks!!
Al
Old Jul 30, 2009 | 01:11 PM
byrun's Avatar
Here is a web site that should help
http://oooo-a3.blogspot.com/
Old Aug 1, 2009 | 05:15 PM
a3driver33's Avatar
Default Thanks!
Thanks! Turns out the cover just pulls off. The attachment points are in the left and right upper corners and the left lower corner, so pulling at those locations one at a time makes it an easy task.
Here is a site that has photos of the cover and the engine, clearly showing the attachment points.
http://forums.fourtitude.com/zerothread?id=3829946
Old Aug 1, 2009 | 05:16 PM
a3driver33's Avatar
lakmun
Feb 28, 2014 11:16 AM
ScottTBurg
Aug 13, 2008 05:31 PM
fcaracol
B7 Models
Mar 28, 2008 01:47 PM
A41.8TQATL
Aug 13, 2005 04:34 PM
aho
Jun 17, 2005 01:45 PM
