A3 3.2 engine noise
Old Jul 22, 2010 | 04:00 PM
spagolli94's Avatar
Default A3 3.2 engine noise
I picked up a 2007 A3 3.2 several months ago and love it. There is one issue that I'm not sure is "normal." Within the first 5-10 minutes of driving, the engine makes a bit of a metallic/raspy noise if I get on it and let the tach climb above 4,000 or so. This happens even when the temp gauge says the engine is fully warm. It's a little hard to tell if the noise is from the engine or exhaust. Just trying to determine if this is a normal characteristic of the 3.2. Thanks in advance...
Old Jul 22, 2010 | 06:03 PM
LWNY's Avatar
I had that once happen to me on my way to the dealer. I thought I might be dragging a branch since there was recently a storm and there were lots of little branches on the ground. I mentioned it to the dealer and they told me a flap (throttle?) was loose and they put it back. Maybe it is the flap that opens the extra length in the intake for higher RPM range.
Old Jul 22, 2010 | 10:15 PM
spagolli94's Avatar
Could be. I'll have to mention it to the dealer when I have it in for the 35,000 mile service in a few months.
Old Jul 23, 2010 | 03:09 PM
spagolli94's Avatar
Today, I had my wife rev the car a bit while I stood outside and listened. The noise is definitely coming from the exhaust. Perhaps it's normal. Either that or there could be a small leak in the system. Sounds pretty cool from outside, actually. I'll post my findings after the dealer looks at it...
Old Jul 24, 2010 | 11:56 PM
cshecks's Avatar
my car has had that sound from day 1. I think it's normal, and you're right, sounds much better from outside than inside the car.
Old Jul 26, 2010 | 12:29 AM
LWNY's Avatar
Yeah, that metallic raspy clank is from the exhaust. I usually hear it when I start the car and go to the rear and do something with the trunk. I don't know how it sounds at higher RPM since I am usually the one driving the car. If the wife is driving the car, it is pretty much always in the 1000-2000 RPM range so I wouldn't notice anything strange.
jraffoul
Apr 10, 2017 06:10 AM
kenman
Sep 12, 2012 02:34 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
