A3 Code P0303 after some BG 44K
Old Jan 30, 2012 | 06:02 PM
DCAV8R's Avatar
Exclamation A3 Code P0303 after some BG 44K
Ok, so I used some BG44k in the fuel system, and today the check engine light came on. Stopped into Auto Zone and got a P0303 error. Car doesn't seem to hesitate and actually seems to be running good. Says it could be:
Ignition Error
Fuel Injector
Engine Mechanical
I was planning on putting in new plugs (She's got 62k on her now). Think I should go new coils too?
Old Jan 31, 2012 | 05:04 AM
jmarshall098's Avatar
P0303 code indicates that there is an engine misfire. But since you mentioned that car is running smooth and is not hesitating, I think you should reset the code first to see if it comes back. If the same code error flashes again, then first thing to look for are the spark plugs. It would be an appropriate decision to change the coil packs too, so that you can ensure a long time performance.
Old Jan 31, 2012 | 07:32 PM
DCAV8R's Avatar
Thumbs up
Thanks! Just hoping for some good weather this weekend
Old Feb 4, 2012 | 03:41 PM
DCAV8R's Avatar
Default Bad cyl
Turns out #3 was bad after all. Had the shop give me the old plugs and coils, plugs don't look great, but the coils still look brand new. Oh well, its the piece of mind knowing everything is new I guess.
Old Feb 8, 2012 | 05:59 PM
DCAV8R's Avatar
Question It's Back!
Engine light back on- guess I have to swing by the auto store again to get another diagnostic. Can't wait for my VAG-COM to get here. Dunno what it could be. Think a fresh tank of gas might help clear it?
Old Feb 10, 2012 | 05:41 PM
DCAV8R's Avatar
Default So-- Learn from my Lesson
Ok, so after the BG 44K the engine light came on and had the error P0303, I went ahead and replaced the coils and plugs, which I probably didn't have to replace the coils, but the plugs were a bit ugly. After the switch, the engine light came back on, but, low and behold, after filling up with gas from a top tier station, instantly, the light went off. I kinda figured that the gas was the issue, so if any of you try the BG44K, let the tank of gas go to just under 1/4 and then fill er up with the good stuff. I will say, I drove to work today (about an hours drive to DC) and I was getting 32MPG! The car is running like brand new. Not bad for a 2006.
Old Feb 13, 2012 | 04:51 AM
Okay so the problem was fuel. It's good that you posted the solution. It will help many users having the same issue.
Old Feb 18, 2012 | 11:04 AM
DCAV8R's Avatar
Red face Here we go again!
Ok, so driving home last night, the CEL came back on. Same issue, Cyl 3 Misfire. Anyone think that maybe its the fuel injector? Is it worth having a fuel injector cleaning service done? I also read that it could be the Oxygen Sensor. Car is running great, MPG is above 31 highway....... Thoughts?
MarkKlockgether
Jun 19, 2013 03:50 PM
DCAV8R
Feb 18, 2012 02:18 PM
less_of_me
Oct 28, 2010 07:03 PM
honnen_c
Jul 11, 2008 01:38 AM
Jxwisniewski
Aug 9, 2007 10:33 AM
