Air Condition
Old Aug 1, 2007 | 05:39 PM
Chef's Avatar
Default RE: Air Condition
ORIGINAL: BAMF
Quick question: There are two buttons in my A3 that seem to indicate recirculating air. One of them has a letter on it, an 'A' if I remember correctly. What are the differences between these two? Also, what exactly does the economy button do? Thanks!
The normal recirc button acts just like you think it should, using only the cabins air through the conditioned system. The problem with that is under prolonged use, the unit may freeze up. The recirc with the "A" will let outside air in from time to time to avoid the unit freezing. Many manufacturers, mostly American, use a small constant amount of outside air to avoid the unit freezing, but it doesn't give you the full effect of the recirc.
The economy button defeats the air conditioning all together. If that is pushed, the car will still try and achieve the temperature you've set, but by using the outside air and heater only.
Hope that helps.
Cheers!
Old Aug 2, 2007 | 04:06 AM
BAMF's Avatar
Thank you Chef! That was quite helpful
Old Aug 2, 2007 | 09:59 AM
lavadrifter's Avatar
I took Stryker's advice on the blackout material. It makes a big difference. As far as A/C, what is critical is that the recirculation button, when pressed by itself, will make the car go slower. Depress while passing.
Old Aug 2, 2007 | 11:17 AM
wtA3's Avatar
Member
Blue Jays is doing just what I do, except no windows down while parked. I got the base version for several reasons and fabric seats was a big factor. I hate sticking to the leather seats, and having a wet butt. I would have liked to have the sport package and a sharp color, but my previous car was black with dark leather and sunroof, the one before that was white without leather therefore I was well aware of what I need in South Florida to be cool, at the expense of not being "cool".
Old Aug 2, 2007 | 11:32 PM
dmacneill's Avatar
The recirculation button with the "A" is the Automatic Air Recirculation, which is linked to the air quality sensor and will automatically switch on the air recirculation if it senses that the air is polluted (exhaust fumes, etc.). This is explained on page 135 of the 2007 Owners Manual.
Old Aug 3, 2007 | 12:37 AM
AManCalledE's Avatar
ORIGINAL: dmacneill
Guess I should [sm=icon_rtfm.gif]because I thought the A was saying that it was a mixure of recirc and ambient air.
Old Aug 3, 2007 | 12:14 PM
Farstrider's Avatar
ORIGINAL: dmacneill
Yup. Altho I wonder how sensitive to air quality it really is. Living in LA I would think the thing must be on recirc all the time.
Also ditto on the Open Sky. I didn't get it in part because of heat (and brightness) and I have had no problems cooling the car down.
willie7182
Oct 23, 2009 04:05 AM
brandywine050
Oct 20, 2009 01:39 PM
bigern45
May 12, 2009 11:18 PM
thmacd
Jan 15, 2008 10:26 AM
madridlover
Mar 26, 2007 11:05 PM
