airbag problem
Old Aug 3, 2011 | 12:09 PM
nugent7288's Avatar
Default airbag problem
hi ive got error codes 00594:airbag ignition circuits:short circuit intermittent and code 01217 side airbag ingniter driver side (n199) short with power intermittent. can any help me with what step to take next and how to fix it. i have a regular mechanic so just seeing if any1 else has had these problems so hes not there all day charging. also im replacing the module as it had code 65535 ecu defective, when i unplugged it had slight burn marks where connection is made, thanks
Old Aug 10, 2011 | 03:43 PM
nugent7288's Avatar
Default solved
changed the module and the airbag light went off, had it hooked up the other codes were just loose connectors under the seat and the steering wheel airbag connection so all solved thanks for the help everyone......... none!!
nugent7288
Aug 3, 2011 12:04 PM
The gaffer
Jun 7, 2009 09:24 AM
kee
Sep 29, 2008 06:43 PM
Dunzie182
Feb 19, 2007 11:29 PM
officecrazy
Mar 14, 2005 07:52 PM
