audi s3 ignition trouble
hi there the problem is as follows in the mornings not everyday maybe once or twice a week turn the ignition on, the indicators wiperes front and rear all work fine head lights work turn everything off with the ignition still on start the engine... indicators wont work wipers and washers front and rear wont wont head lights on dipped beam wont work side lights do work not checked the main beam as yet... once the engine has ben running 20 seconds turn it off start it again and sometimes everything will work other times you will have to drive it down the road for couple mins turn the engine off and start it again... when it is working its working it wont stop working while your driving and it also wont start working unless you turn the engine off and start it again i dont know if any one has come across this problem befor i was wondered if there either a ignition relay system on it iv heard some models have 3 relays directly off the ignition weather its one of these playing up or may the body control unit its been pluged in to a snap on comtuer while this error was occuring and there was no error codes coming up.. any idea would be greatefull cheers guys!!
koenig22
Audi Q7
Mar 26, 2014 08:54 AM
