CAI Water Troubles?
Old May 3, 2007 | 01:46 PM
ryandlor's Avatar
Default CAI Water Troubles?
Just wanted to get an idea if anyone who has installed a CAI has had any water problems with flooding. One of my friends had a CAI previously and basically blew his turbo when he waterlogged his CAI during a storm. He told me to be a little wary.....
Anyways, I know the Carbonio is covered but the better ones from EVOMS and such are wide open and I'm thinking there may be a problem with sucking in alot of water.
Any feedback would be appreciated...
Cheers
Old May 4, 2007 | 07:16 PM
ryandlor's Avatar
Default RE: CAI Water Troubles?
no ideas?
Old May 4, 2007 | 07:33 PM
Chef's Avatar
Always a possibility, but more so if the CAI is located way down to the ground with the extension. I'm not too worried about the location of mine inside the engine bay.
Cheers!
Old May 4, 2007 | 08:34 PM
quadric's Avatar
I had a similar discussion today with a friend who has a VW MKIV 1.8T for which most some CAI are made to go through the side panel and into the wheel arch. Fo me I would never do that as Chef stated, more prone to water. I just installed the EvoMS CAI and I must say for water to get into that it has to be some tricky water considering it is in the engine bay and has a nice shielding box around most of it. I think if the CAI on any engine is in the engine bay you are not likely to get hydrolock (water in the engine from CAI).
Old May 5, 2007 | 08:47 PM
mattrazzo's Avatar
There are water relief valves available, but I have no idea if they really work. A demo shows them trying to suck solid water and the valve works. I guess I'd still be concerned about partial water uptake.
http://www.aempower.com/ViewCategory.aspx?CategoryID=20
If you simply take in air above the wheel wheel (in the engine bay for example) you'll do fine.
Read more here:
http://en.wikipedia.org/wiki/Cold_air_intake
Old May 6, 2007 | 09:19 PM
ryandlor's Avatar
Much appreciated all.......
Old May 6, 2007 | 09:46 PM
falcompsx's Avatar
FYI, dont use a bypass on your car.
"The AEM Air Bypass Valve is C.A.R.B. exempt on AEM Cold Air induction systems only and is NOT for use on forced induction vehicles."
Gloern
Aug 29, 2009 07:01 PM
lyosha
Jun 22, 2009 09:59 AM
kp99audiA4
Dec 2, 2008 01:18 AM
KissMyAsS4
Aug 30, 2008 08:53 PM
