huge plume of smoke?
Engines been runin a little sluggish lately...
Gave er a bit of juice today to test er out and had er up to 5500 rpms in 3rd then suddenly a huge plume of smoke came off my back end....and i mean huge. 5500 rpms isnt to high?
one factor may be i filled up on some oil because my chech oil light came on....i sthis just excess oil?, if so why only at 5500rpms?
Car kept ruuning smoothly, parked it for about 5 hours. Then did the same thing agian, came off an onramp onto the 401 and 3rd, 5500-5800rpms, huge plum of smoke..
wats goin on?
wats goin on?
Was the smoke blue? You should check your oil level like, ASAP. I read in one of the posts on here that it is worse to have too much oil than to be a little low in this engine. And FYI, low oil level won't throw a code, you will get a low oil level message on your DIS. Is the code still on? If so you should get it scanned, it may have something to do with your smoke plume.
ORIGINAL: BAMF
How much damage did i do? and 5500rpms shouldnt be a problem right?
triplerr
May 25, 2013 08:19 AM
drummr8
Apr 5, 2013 11:52 AM
