Oil leak
Old Apr 1, 2012 | 06:59 AM
Dannyboy4's Avatar
Default Oil leak
Hi I have a 1.9tdi a3 with a slight oil leak from intercooler. Iv checked the turbo seems fine. I've come to the conclusion of the ccv. Is there anything else I should look for. Also it has used about one line of dots on the dipstick in about 1k miles is that ok.
Is there any thing I can do to stop it.
Cheers Dan
Old Apr 1, 2012 | 09:20 AM
M5S5's Avatar
Tech Certified
You could have a turbo going bad. Might not be a bad idea to pull the intake hose off the turbo & take a look.Very common on the TDI's.
Old Apr 1, 2012 | 09:24 AM
Dannyboy4's Avatar
Iv pulled of the pipes and checked it. Tge shaft only has very minimal play and there is only a light film of oil inside.
The ccv has oil leaking out the joint that's why I thought maybe that.
It's a pd engine if that makes any difference.
Cheers for the reply
Dan
Old Apr 1, 2012 | 09:29 AM
M5S5's Avatar
Tech Certified
Not sure what you mean by a pd engine. What 3 letter designation is the engine like ALH?
You mentioned TDI , IT is a diesel right?
Old Apr 2, 2012 | 09:31 AM
Dannyboy4's Avatar
Ye it's the pumpe Duse diesel and I think it's ATD
Cheers Dan
Old Apr 2, 2012 | 08:08 PM
M5S5's Avatar
Tech Certified
Not sure of the mileage & wear of your engine but it could have a little excessive blow by the rings. Audi says that 1 quart in 1000 miles is acceptable (pretty sad because that for new cars also).
Also i was thinking. The intercooler should not leak , it is a sealed item. I would see if there are seals to replace so it does not leak externally. Most of the time you do not realize there is anything in the intercooler unless you disconnect the piping or remove them & then see the oily ooze come out.
Just something else to chew on for a bit.
Old Apr 3, 2012 | 02:26 AM
Dannyboy4's Avatar
Cheers will get my hands dirty on my next day off.
I will also clean the exterior of the intercooler an chech for pin holes.
Cheers for the advice
Dan
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
