Over heating Problem HELP!!
Old Dec 25, 2009 | 05:25 PM
lockee73's Avatar
Unhappy Over heating Problem HELP!!
HI
I have a A3 1.8 1996 model the problem im having is that the temp gauge is hi in the hundreads but the is only cold air blowing out the vents hase anyone got an idea wot the problem would be
Thanks
Old Dec 25, 2009 | 05:37 PM
Midniteoyl's Avatar
Check your fluid level and try to burp any air out.. Other than that, it could be the thermostat or even the water pump....
Old Dec 25, 2009 | 05:55 PM
lockee73's Avatar
The fluid level is ok but was low,wots the best way to try and get air out off the system thanks
also it did blow hot air for a few mins and the temp gauge went down a bit
Old Dec 25, 2009 | 06:59 PM
Midniteoyl's Avatar
On the 1.8, most recommend unbolting the reservoir and holding it up higher while opening the bleed screw in the heater hose just before the heater core, with the engine idling and warm enough to open the thermostat (not hot).
Old Dec 26, 2009 | 04:24 AM
lockee73's Avatar
Thanks ill have a go at that this morning and see how it goes
Old Dec 26, 2009 | 06:23 AM
lockee73's Avatar
Hi could someone please tell me where i would find the bleed screw ive been looking all morning and i just cannot find it
Thanks
Old Dec 26, 2009 | 03:48 PM
Midniteoyl's Avatar
Here's what I could find.. The problem is that its for an A4.. I guess there's not really a bleed 'screw' for the A3/A4 of that year, only a bleed 'hole' and its hiding in the heater core hose nipple..
To fill without using special tools, loosen coolant expansion tank and lift about 4" (100 mm). Remove grommet holding clip at heater core and pull back grommet. Loosen coolant hose on heater core and pull back hose sufficiently so that bleeder hole is no longer sealed by connection. See Fig. 14 . Add coolant until it flows out of coolant hose bleeder hole. Push coolant hose on connection and tighten. Install coolant expansion tank cap.
Start engine, and raise engine speed to 2000 RPM for approximately 3 minutes. Allow engine to idle, until lower radiator hose is hot. Check coolant level, and top off if necessary. When engine is at normal operating temperature, coolant level must be at MAX mark on expansion tank. When engine is cold, coolant level must be between MIN and MAX marks, on expansion tank.
Name:  A4 bleed hole (Small).jpg
Old Dec 27, 2009 | 05:33 AM
lockee73's Avatar
Cheers for that
Old Dec 27, 2009 | 06:33 AM
Midniteoyl's Avatar
Hope it helps...
DaveQ7
Audi Q7
Sep 16, 2014 01:58 PM
Julianpnc
Oct 23, 2012 04:15 PM
Paul Rasmussen
Oct 10, 2012 08:51 PM
plumbous
Dec 15, 2009 10:19 AM
jj2345
Aug 21, 2009 11:06 PM
