Rear seatback latch noises
Old Mar 26, 2007 | 01:25 PM
drumdork03's Avatar
Default Rear seatback latch noises
OK, this started over the weekend and is driving me nuts. Noises have started from the c-pillar areas that I'm pretty sure are the latches holding the rear seatbacks in place (b/c I fold down the seats and close them firmly and the noise goes away for awhile).
Has anyone tried lubing the mechanism (inside the seat)? And what type of lubrication is recommended? Or is there another solution? I don't want to gunk up the mechanism.
The stealership just wants me to "bring it in" and that's inconvenient.
Old Mar 26, 2007 | 02:24 PM
rich1068's Avatar
Default RE: Rear seatback latch noises
Try adjusting the headrests first. It could be them and not the seats, it was on mine.
Old Mar 26, 2007 | 03:42 PM
drumdork03's Avatar
Thanks. Nope, definitely not the headrests though.
Old Mar 26, 2007 | 08:03 PM
falcompsx's Avatar
i've noticed that squeaking when i have oneseat folded down, but never when they are up. Maybe try some lube on one of the latches, i'd try a silicone based lube
Old Mar 27, 2007 | 03:42 AM
drumdork03's Avatar
Found some info on the VW forums about wrapping the bolt on which the latches lock with tape, so there's less play. Maybe I'll try that before making a mess on the inside of my seatbacks.
Local weather has quickly changed back and forth between near-freezing and summertime, so I'm pretty certain things will settle back into place when the weather is a little more consistent.
Old Mar 29, 2007 | 04:00 PM
drumdork03's Avatar
So wrapping the bolts with tape didn't work. Well it did for a bit, but releasing the seats again caused something in the mechanism to press thru the tape. I can't even find a way into the seatback to see what's up in there.
Old Mar 29, 2007 | 09:53 PM
Copa2's Avatar
Hello , I have the same problem and it is the seat latch , whatI did to fix the problem after the dealer told me that they had to take everything apart , ( didn't like that idea at all ) was to buy some hockey tape and rap it around the latch on both sides and it's been noise free for over 3 months now , eventually the noise will come back but I still have plenty of tape left , hope that this might help.
Old Mar 30, 2007 | 04:41 PM
L7's Avatar
L7
ORIGINAL: Copa2
For the southerners and warm weather members, please allow me to translate: friction tape.
Formerly of the hockey playing north, by way of the south and then even deeper south and now still just barely below the Mason-Dixon line.
Runningfarr
Mar 13, 2014 11:10 PM
zool
Aug 15, 2013 04:10 PM
Milez
Jun 24, 2013 01:06 AM
dandunham
Feb 18, 2011 07:20 AM
KingWulfgar
B7 Models
10
Jul 24, 2010 09:27 PM
