Reverse in my A3 is acting up
Old Jan 24, 2013 | 06:45 PM
4mymalamute's Avatar
Default Reverse in my A3 is acting up
I have a 2006 A3 with the 3.2 and 111k miles on it. I have done all the maint. on it since I purchased it this past year. DSG service was done as well as Haldex. The problem is, whenever I put the car in reverse on ANY slight hill, it seems I have to floor it to go. Seriously, not the typical give it gas and go but the peddle half way down with rpms around 3-4k....and even at that point the car barely moves. So, I have been searching around but havent found much on this subject. Anyone have some advice or input?
Thanks in advance.
Old Jan 25, 2013 | 09:38 AM
Anyone?
Old Mar 10, 2013 | 05:26 PM
RobotSoup's Avatar
Originally Posted by 4mymalamute
Anyone?
I have the same model with 105k and a similar issue. I'm going to get the transmission fluid changed soon. I'll let you know if that helps.
Old Mar 12, 2013 | 09:50 AM
Thanks. Mine still has the issue but I drive it daily and been ok (well seems like its just normal I think?)
Old Mar 13, 2013 | 09:23 PM
RobotSoup's Avatar
I don't see a difference after a transmission fluid service. The Indy mechanic said the speed was normal and reverse should be slower than 1st gear.
Old Mar 14, 2013 | 02:33 AM
LWNY's Avatar
Do DSG adaptation, where clutch engagement point, pressure, etc are recalibrated
6-Speed Direct Shift Gearbox (DSG/02E) - Ross-Tech Wiki
Old Mar 14, 2013 | 09:36 AM
I did this two weeks ago...car shifts a bit better but reverse is still the same. Just seems strange. On the slightest hill I put it in reverse its seriously 3.5-4.5 rpm just to get it to move. Other than reverse, the car seems normal. Strange.
Cris_A
Nov 22, 2009 10:45 PM
Cbass
May 13, 2008 08:56 PM
chris
Dec 27, 2007 09:02 PM
42sport
Jul 5, 2007 12:09 PM
Novablue454
Sep 26, 2005 03:30 AM
