Ruined a rim, can I replace w/ a replica?
Just get the wheel refurbished it will save you money plus u will have all oem wheels on your carand you wont have the weight issues.... besides im sure you dont want a replica ona newer car kinda cheezy IMO
I am looking at the TR-1's as well but, by my calculations,the ET +48 offset on those means that they will stick out just over 14mm further than stock.
Dependable Wheel Repair
415 S. 7th St.
Renton, WA 98056
(425) 226-8711
http://www.DependableWheel.com
Great group of good people. Tim is awesome at his work and he knows how to treat his customers.
bent. i don't think its worth fixin'
Goodluck!
Is it common to find shops that will refurbish rims? I live in West Lafayette, IN (home of Purdue University), and I'm pretty sure I bent one of my S4 replica rims by hitting a curb. I bought the car used (1999 A4 1.8T Quattro) and it already had the S4 wheels on it. I know they're 17", but I don't have the slightest idea what the offset is. I don't feel very confident buying another replica online, cause I'm unsure of whether it will match the other 3 or not.
Tire Rack seems to list wheels with ~35mm offset. The replica site above had 42mm and 45mm. So lost...
Yea, depending on your area, refurb shops can be pretty common. "Good" shops are a little less so, so be sure to do your research. Google will handle that for you most of the time(both finding and researching). Words like "Wheel, Rim, Repair, Service, Fix, Scratch, Bend, Bent" and the like.
As for offset, you can take your wheels to a reputable tire & wheel shop: Les Schwab, Discount Tires, Big-O, Goodyear, etc... Tell them your problem and that you'd like to know if they have your wheel or a potential replacement available and ask them what the offset is. Obviously, we don't expect they'll have a replacement, but they do know how to check for the offset.
Replacement "replica" is probably going to be quite the task. If you go this route, be sure you buy the same model from the same manufacturer (and same year if possible). You'd be surprised at theminor "tweaks" they do to wheels each year to be able to call it "new." If you're not a detail person and this is not a show car, you probably won't care. However, you will find differences (not to mention the performance/weight issues already discussed) if you replace one wheel with an off-make/model.
Seriously, repair the one, replace the one with anIDENTICAL, orreplace the SET... Those are really your only (at least best) options.
