Turbo not kicking in
Old Jan 7, 2012 | 12:41 PM
WillA3's Avatar
Default Turbo not kicking in
hi,
I have a 2001 a3 1.9 tdi and for a few weeks now i have not had any turbo boost. Its like im driving a bus and is so slow it makes me want to weep.
have replaced MAF, didnt fix it.
Have replaced N75, didnt fix it.
what other options do I have?
thanks for any help.
Old Jan 7, 2012 | 01:47 PM
turbo kraut's Avatar
Tech Guru
Just curious why do you say the turbos no kicking in? Do you have a boost gauge?
If you do does the gauge read in -ing at idle? Does it move at all when you press the gas pedal?
Does it idle normal? Any vac leaks?
Not a big time diesel mechanic. Just using my petrol expierience here
Old Jan 8, 2012 | 11:26 AM
WillA3's Avatar
No I havnt got a boost gauge. Basically I mean I floor the car in 2nd and no soot out back, no power and basically labours slowly up to speed with high revs. What is idling normal? And how can I check vac leaks? Desperate to fix, just been on a long drive and I can't believe the amount I pay for insurance for the speed I get. Thank you for the help.
Old Jan 8, 2012 | 11:37 AM
Tech Guru
Well get a boost gauge first and foremost. Vac leaks can be tested w/ smoke by feel or with a tester.
Old Jan 16, 2012 | 09:52 AM
mikelenoard's Avatar
this is the same problem i am to facing and waiting for the solution. please guys help me.
Old Jan 17, 2012 | 09:25 AM
WillA3's Avatar
Still no luck. Havnt had much chance to fiddle yet though. Will test vac pipes for leaks/blockages. Would a faulty N81 valve affect? I've heard blocked air filter may?
Project
Apr 22, 2008 11:38 PM
sean1.8t
Nov 14, 2007 10:38 AM
jukeit
Dec 14, 2005 03:58 AM
tcsaudia4
Sep 24, 2005 01:44 AM
rudeboy88
May 19, 2005 04:43 AM
