**UPDATE**My BOV on B6 1.8T**Throwing codes like a mofo
Old Dec 21, 2007 | 10:08 PM
AUDI05's Avatar
Default **UPDATE**My BOV on B6 1.8T**Throwing codes like a ****
Well,
Just the other day I installed my Forge-004 on my B6 1.8T CVT. The car drove great for the first couple hours, then it threw the engine check light at me. So I repositioned the BOV before the T eliminating the reservoir. I then re-set the ecu, and again it drove good today. Tonight the engine check light came back, and its not driving the same.
In conclusion, I do not need this hassle and don't want to mess my car up. I ordered a new stock dv and should have it next week. In the mean time I will drive minimanly and as soon as the sock dv arrives I WILL remove the Forge004.
Nothing but troubles [&o]
Old Dec 21, 2007 | 10:18 PM
Bogie's Avatar
Default RE: **UPDATE**My BOV on B6 1.8T**Throwing codes like a ****
You're doing it wrong.
Anyway, you don't even need anything better than your stock dv. You're not even chipped.
Old Dec 21, 2007 | 10:22 PM
Karl's Avatar
what were the codes?
Old Dec 21, 2007 | 10:25 PM
AUDI05's Avatar
ORIGINAL: Bogie
Its hooked up just like you told me too. I don't see what I did wrong....
Old Dec 21, 2007 | 10:29 PM
Bogie's Avatar
you probably jsut broke or disconnected a vacuum line or some electrical connector somewhere while trying to install the BOV. Did you inspect the BOV before installing it, or just take it out of the box and try to put it in? If you post the codes you got, we can probably tell you if it's a vacuum leak, etc... and help troubleshoot.
Old Dec 21, 2007 | 10:31 PM
Karl's Avatar
like i said before...
Old Dec 21, 2007 | 10:40 PM
AUDI05's Avatar
I can't help you there, I don't have a vag com. I should have said throwing engine check lights. Any body here close to tampa FL with a vag com? My bad bogie, thanks for your help
Old Dec 22, 2007 | 12:52 AM
aRIf's Avatar
r u sure you have the right spring with that bov?
is it 100% bov?
Old Dec 22, 2007 | 12:56 AM
AUDI05's Avatar
I have the green spring in it. (I believe the green is for 5-15 psi).. Are you suggesting using a stiffer spring?
Old Dec 22, 2007 | 01:00 AM
aRIf's Avatar
Is it close at idle?
I think you have missfiring and spark plugs will blacked out versy soon and car will start to die randomly, then it will be hard to start it. keep a spare park plugs and the tools with you for incase.
go to advance auto parts to see your CEL codes. they check it for free
