[[Elim 2871R Dyno Result]]
Old Mar 20, 2006 | 12:23 PM
  #61
aRIf's Avatar
Default RE: [[Elim 2871R Dyno Result]]
ORIGINAL: liquidxit2
ORIGINAL: aRIf
ORIGINAL: Jeff
i wanna see 300whp from your car
I hope we'll see it soon. I decrease the fp today and I'm still not getting any timing, i'm still very little rich. I logged about 30mins and only from a cyclinder 3 got like 1° ones and that's all, rest are 0°
ones I clear out the race gas, I'll get better logs I think. I dont understand others who got same setup like me pulling a lots of timing but not me.
*Race gas do make difference because I can turn the boost more without pulling huge timing issue, this is what Sean told me.
what boost are you running? try lowering the boost a little, I have found that that is the culprit of pulled ignition timing in most cases.
23psi for now. when I was running 19psi, I was gettin some timings accually but %80 of log were 0°
Old Mar 20, 2006 | 12:45 PM
  #62
prodrive's Avatar
why others getting lots of timing ? we need some other dyno results [sm=feedback.gif]
Old Mar 20, 2006 | 01:31 PM
  #63
aRIf's Avatar
ORIGINAL: prodrive
One guy is running the same setup like me witout fmic, and cat back system. I think that's because of hot air flow problem, he's gettin around 10° timing.
Old Mar 20, 2006 | 01:58 PM
  #64
InsaneHatter's Avatar
by "Getting timing" are we talking CF here? Correction factors?
You may be running low CF's because of the race gas, you may not get more power, but it prevents your knocking factor.
Use up all the race, go put in the highest octane available ( BP 92 if you got it .. best gas.. no detergents .. less oxygenated)
Run about 3 times, and see timing..
Send the logs to uni, have them adjust.. they may be able to advance a few degrees of timing.
IMHO your dyno plot is way to linear in the torque, (45 degree angle) needs to have a high jump, level off, and go lower near readline..... The timing advance may get your to spool full boost before 4750 RPMS...
MasterV
Jun 2, 2008 12:37 AM
pitrman
Dec 10, 2007 07:18 PM
aRIf
Apr 19, 2006 04:55 AM
aRIf
Mar 17, 2006 05:21 AM
aRIf
Mar 16, 2006 12:34 PM
