1.9 TDi Smoky Exhaust
Old Aug 20, 2005 | 06:38 AM
Zappa's Avatar
Default 1.9 TDi Smoky Exhaust
Hi,
wonder if anyone can throw a light over what is causing the excessive black smoking from my exhaust on a 1997 1.9 TDi?
I have been noticing a steady drop in power especially uphill and if the car is made to work in a higher gear, this results in a mass of Black Smoke from the back!!
On the flat with no load it is fine, but put ya foot down and out come Greenpeace waving their banners
All the filters air / fuel / oil etc have been changed & obviously fuel consumption is higher than normal.
Maybe have to end up at the Audi dealers to put it on the Vag-Com ??
However, just wondered if there was anything else I could try before emptying my pockets at the garage?
Cheers
Z
Old Aug 20, 2005 | 11:48 AM
Jestnomen's Avatar
6th Gear
Default RE: 1.9 TDi Smoky Exhaust
Are you burning excessive amounts of oil?
Old Aug 20, 2005 | 01:03 PM
david9999's Avatar
I hate to redirect a new member, but the Audi TDI isn't imported into the US, so most of us don't have much experience with deisel engines. You might want to check the VW forums where the TDI is imported here.
Dpeending if your greeting was an Australian or UK "cheers" you may be able to find someone with a vagcom who will allow you to use it. The cost is usually beer.
Check this link for the vagcom locator.
Vagcom
Old Aug 20, 2005 | 06:18 PM
Zappa's Avatar
Hi Jestnomen
no I am not burning any engine oil it looks more like there's too much fuel going thru the injecters?
Thanks david9999
for the vagcom link
Cheers
Z
Old Aug 20, 2005 | 08:39 PM
Toff_the_Toffee's Avatar
I had an A3 tdi 130 but superchipped it! What a monster. It really had some serious power! It would wheelspin in 4th if you never had the traction control on, and even then the tc light was lickering on constantly!!
No idea what would make it bellow black smoke. Could be anything from a turbo, to burning oil. Does it still have the same power from before the smoke came? If not, then it could well be a turbo. I'm not really up with deisels though, so best go and ask at a professional place...
Old Aug 26, 2005 | 06:27 AM
Zappa's Avatar
Update on the problem.
I took the car to a local VAG-COM garage where they discovered that the problem was caused by a split Turbo pipe and after taking a trip to the Audi spares dept (and £50 later) the problem was solved!
No more black smoke & turbo restored to full power......
Thanks to all who tried to help
Regards
Z
Old Aug 26, 2005 | 12:28 PM
Tell me more about the tdi... I loved the power of mine! What engine is it> 115, 130, or the 150? My 130 had a superchip lobbed in it, and a magnex exhaust. The power was amazing for a diesel. Used to wheelspin in 4th!
agazoo
May 16, 2008 01:57 PM
auDi1.8TQ
Apr 19, 2007 09:05 PM
kadajx666
Dec 30, 2006 04:42 PM
auDi1.8TQ
Aug 4, 2005 06:07 AM
Hikerlaird
May 7, 2004 07:45 AM
