1997 1.8T, low idle at traffic stops
Old Aug 8, 2006 | 10:55 PM
gregp1962's Avatar
Default 1997 1.8T, low idle at traffic stops
After coming to a stop, my idle falls to around 400 and almost dies. It only happens after decelerating. And, if I tap on the gas peddle, the idle goes up to around 900-1000 I don't see that these engines have a conventional idle control valve. I believe the throttle body to be clean. What else can cause low idle.
1997 1.8T, Auto trans.
Old Aug 8, 2006 | 10:59 PM
onepoint8tee's Avatar
Default RE: 1997 1.8T, low idle at traffic stops
vac leak, fuel pump, fuel filter, 02 sensor, ects, maf, the list could go on.
Old Aug 8, 2006 | 11:12 PM
quattrosedan's Avatar
double check all of your connections, possibly your icm, a friend of mine had that problem too.
Old Aug 9, 2006 | 01:03 AM
get your ecu scanned for any stored fault codes.
Slinkey
Jun 5, 2011 08:09 AM
joshpsu
Jan 26, 2011 02:35 PM
motorrad
Sep 30, 2008 09:49 AM
TheIncrdbleGary
Nov 7, 2007 12:09 AM
gregp1962
Aug 5, 2006 02:52 AM
