1998 1.8T question
Old Aug 16, 2006 | 12:09 AM
straitgame22's Avatar
Member
Default 1998 1.8T question
I have about 91000 miles on my 1.8t and all of a sudden today the "air bag" light came on. I live in las vegas, and it was extremely hot today. Does anybody know a remedy for this obnoxious problem?
Old Aug 16, 2006 | 08:15 AM
david9999's Avatar
Default RE: 1998 1.8T question
Scan for codes with a VAGCOM (use the vagcom locator to find one) and clear it. If it recurs you may need to fix your airbags.
Old Aug 16, 2006 | 01:45 PM
Member
a friend, who has never had an audi, said to just pull the fuse and then after it resets to put it back in. is there even a fuse for that? Also he told me that the heat causes it to do this and that after it cools down significantly it will turn off... Please assist me, i have no idea what to do?
Old Aug 16, 2006 | 01:49 PM
clconversion's Avatar
could be a bunch of different issues causing this to happen you will have to get it checked out forsure
but do not be afraid to drive the car and have the airbag blow up in your face with the airbag light it it disarms the system and will not blow
Old Aug 16, 2006 | 01:52 PM
Member
Could my chip affect this at all?
Should i take to a dealer or would a certified audi mechanic work?
Old Aug 16, 2006 | 05:58 PM
GeilKyle2's Avatar
I don't think the chip would affect it, a certified audi mechanic should be able to do the job
Old Aug 16, 2006 | 06:09 PM
socal_A4's Avatar
first of all this is a touchy situation.... it could be your just throwing a code... but if it isnt wouldnt you want to know that your airbags will deploy... my friend had the same problem it costed him over 800 to fix it at the dealer, because that is something the dealer has to fix not a normal mechanic... try this clear the code..if it comes back after you clear it, take it to get it fixed... it will cost you a nickle but then you have to ask yourself how important is your life
eriklane
Jan 25, 2015 08:40 PM
Schimke
May 3, 2012 09:49 AM
Heber
Jan 13, 2010 03:16 PM
lookingforanaudia4
Feb 19, 2006 06:22 PM
bond316
Jun 9, 2005 09:01 PM
