1st time ok 2nd time its a problem
Old Aug 8, 2007 | 06:19 PM
theguy1084's Avatar
Default 1st time ok 2nd time its a problem
First off this is the 2nd time this happened. The first time about about 2 months ago. So anyways I am on my way home from work and the car feels normal. Then I get on it and it has no power. Pedal is to the floor and it feels like only 1/4 throttle. Boost only spiked to about 8psi then held at about 4psi. It did this for about 5 miles and then went back to normal. No CEL. Not sure about codes. I will check those when I head into work tomorrow. I dont think there was any the first time either. I did hook the scanner up this morning to check a few things out. Value block #32 was 0.0% and -0.8%. I also did a throttle adaption. I kinda suspect the throttle body only because last time I tried to adapt it it was saying error. It took 3 times to adapt it about a month ago. Just food for thought. I am going to check it out more when I get to work but I was just wondering what you guys thought.
Waxmanronnie
Jul 3, 2014 04:18 PM
bdaroci2010
Dec 16, 2012 04:11 PM
zerinTT
May 20, 2008 09:56 AM
ClemsonKev
Aug 11, 2006 08:06 PM
T and A4
Mar 17, 2005 02:44 PM
