2001 Audi A4
Old Jul 31, 2007 | 11:14 PM
01A4T's Avatar
Default RE: 2001 Audi A4
Depending on how scarce A4's are in Canada, 13.5K US dollars or 14.5k Canadian dollars is waaaaay too pricey if B5 A4's are readily available....
Old Aug 1, 2007 | 12:13 AM
outasflyguy's Avatar
ORIGINAL: acetrebo
The clutch on these is that way, its perfectly normal, you'll get used to it quickly.
Run 91 octane, 93 if you are chipped.
not every1 here in Norcal gets 93 octane.... i havent seen anything higher than 91
Old Aug 1, 2007 | 11:19 AM
acetrebo's Avatar
I think no-one in CA gets 93 at all.
Here in humid OHio, 93 is as prevalent as ice cubes arefor an eskimo.
Old Aug 1, 2007 | 04:04 PM
BlueMagic's Avatar
I realize you did say Audi's are a bit more pricey up there, but it should be around 9 or 10k in US$. You'll want to make sure the timing belt has been changed, as well as both o2 sensors. Ask for any documentation the seller has on the maintenance history.
Wtftylor
Nov 1, 2012 01:01 PM
nukauto
Feb 2, 2008 11:02 PM
Jorgen
Aug 7, 2006 11:29 AM
Bit646
May 11, 2006 05:24 AM
