2008 Audi A4 turbo problem
Old Jun 2, 2015 | 03:50 AM
Audia4turbo323's Avatar
Default 2008 Audi A4 turbo problem
So I bought this audi it was running fine but then the check engine light came out I took it to the mechanic shop a couple of codes came out like p2294
P0444 p0033 p0243 so the mechanic said it was the turbo I replace it and know it doesn't get past 60 please help
Old Jun 3, 2015 | 08:46 AM
rhodes991's Avatar
You can generally google the codes:
P2294
18726/P2294/008852
Contents
[hide] 1 18726/P2294/008852 - Fuel Pressure Regulator Valve (N276): Open Circuit 1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
1.4 Special Notes
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Wiring and/or connections faulty
Fuel Pressure Regulator Valve (N276) defective
Possible Solutions
Check wiring and connections
Check / Replace N276
Special Notes
On some engines, the N276 may be refered to as the N290 in the factory wiring diagram.
P0444
001092/P0444
Contents
[hide] 1 001092/P0444 - EVAP Purge Control Valve (N80): Circuit Open 1.1 Possible Symptoms
1.2 Possible Causes
Possible Symptoms
MIL on
Possible Causes
Blown fuse
N80 Faulty
Wiring and/or connections faulty (open circuit)
Possible Solutions
Check fuses
Ohm test N80 valve
P0033
code 00051 P0033 TURBO CHARGER BYPASS VALVE CONTROL CIRCUIT
on the inlet side of the turbo there's a solenoid type of valve that diverts the high pressure air when you close the throttle - also known as a 'dump valve'
the valve is a simple 2 wire device so 1st unplug it and inspect the wire for damage and the connector for corrosion
if this looks OK then I'd suggest replacing the valve as they're not too expensive
P0243
P0243 Volkswagen - Turbo/Super Charger Wastegate Solenoid 'A'
0 | Add Comment
Possible causes
- Faulty wastegate solenoid
- Wastegate solenoid harness is open or shorted
- Wastegate solenoid circuit poor electrical connection
What does this mean?
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
P0243 Volkswagen Description
The ECM has detected a signal outside parameters on the wastegate solenoid circuit
I say take it back to the mechanic as it looks like they didn't hook everything back up correctly.
sebasn
Apr 30, 2013 06:03 PM
Dyfan001
Aug 28, 2012 05:14 AM
O_So_Dank
B7 Models
Jan 7, 2012 05:16 AM
fchen911
Mar 6, 2009 04:00 PM
SickRS4
Mar 14, 2008 10:22 PM
