A4 battery
Old Feb 25, 2005 | 02:57 PM
bobc's Avatar
Default A4 battery
Sorry if I put this post in the wrong area, new to the forum.
We recently bought a 96 A4 for our son. It sat for a week without being operated and the battery went completly dead. After charging, it wont start. Turns over great, has spark, no fuel. Fuel pump fuse is ok. Is there something I should try?
BobC
Old Feb 25, 2005 | 06:15 PM
CRAZYHAWK's Avatar
Default RE: A4 battery
Do a search for Vag Tool Locator.
Old Feb 25, 2005 | 08:29 PM
bobc's Avatar
ok I give, what is that?
Old Feb 25, 2005 | 08:44 PM
CRAZYHAWK's Avatar
It is a tool for diagnosing problems with VWs and Audis. You are going to need it to set up the ECU with initial settings , that allow your car to start. Locate someone with this VAG COM.
Old Feb 25, 2005 | 09:05 PM
DerMeister's Avatar
If you have a near by garage you could take it there and have them do a quick electrical system check. Some places don't charge and some do and allow you to place that system check charge toward the purchase of the needed replacement part.
Old Feb 25, 2005 | 09:38 PM
david9999's Avatar
I hate to ask, but you say there is no fuel at the engine.
Is there fuel in the tank? Could be a faulty gauge which reads 1/4 when the tank is empty. Try adding a few gallons of premium and then re-try.
It could be a bad fuel pump or bad connection.
some of these things can be diagnosed with a Vag-com as outlined above. Follow the link to the Vag-com locator and see if there is someone local that would be willing to come over and help out an enthusiast.
The famous link
