A4 gear linkage
Old Jan 2, 2007 | 11:54 AM
joemc99's Avatar
Default A4 gear linkage
Hi, I am buying a 1998 A4. The gear linkage seems sloppy, ie, there is a lot of play at the gearstick. Does this seem normal? Mate has an A4 and the linkage feels a lot stiffer. Joe
Old Jan 2, 2007 | 12:14 PM
ImTheDevil's Avatar
Default RE: A4 gear linkage
Probably the bushings on the shift lever (down below the boot) are worn. Should not be a difficult DIY fix. I've done this on other cars, and it's not tough - you just want to be careful not to drop anything down through the hole once you have the shift boot taken off.
Old Jan 2, 2007 | 12:21 PM
joemc99's Avatar
Thanks Jeremy. I just test drove antoher A4, same feeling. I will ask the dealer to inspect it before I buy.
Old Jan 2, 2007 | 12:39 PM
ImTheDevil's Avatar
No problem - BTW, shift bushings tend to be quite inexpensive (I've gotten them from the dealership for other cars for around $8 each) so it's not going to be an expensive repair. If that's what it turns out to be, and you want the car, see if you can make that repair part of the deal ("Tell you what - replace the shift bushings and it's a deal, I'll buy the car"). A mechanic can have it done quickly (likely less than an hour) and in order to guarantee selling the car, I can see them doing that. When I bought my 300Z, they agreed to replace a bad wheel bearing in order to seal the deal. By comparison, shifter bushings are a no-brainer.
Old Jan 2, 2007 | 01:45 PM
joemc99's Avatar
Thanks, will do, I'll let you know. Joe
shady927
May 6, 2010 11:35 AM
dhenson2342
Mar 14, 2009 08:17 PM
ronin23
Mar 23, 2008 11:42 PM
micahsutton
Sep 30, 2007 12:22 AM
ADubyaD
May 11, 2007 08:52 PM
