A4 misfiring?
Old Jan 14, 2005 | 02:41 PM
powerboat's Avatar
Default A4 misfiring?
1999 A4, 2.8L engine, 5 speed Auto.
Engine starts after long crank. Then VAG-COM gives me a message: "Multiple misfiring all cyllinders"
Above 2500 RPM works smooth, has power.
Under 2500 RPM start misfiring again.
Tested with VAG-COM.
Error message: "Multiple misfiring all cyllinders"
Anyone has any idea what's going on??
Thank you.
Old Jan 14, 2005 | 02:59 PM
brrman's Avatar
Default RE: A4 misfiring?
is that the entire error code? can you post everything the VAG says?
Old Jan 14, 2005 | 03:17 PM
dudley doright's Avatar
I would suspect that you have a vacuum leak.
ORIGINAL: powerboat
Thank you.
Old Jan 15, 2005 | 01:06 PM
powerboat's Avatar
Thank you all for your inputs.
Error codes are:
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16689 - Cylinder 5 Misfire Detected
P0305 - 35-00 - -
I pressure tested the cyllinder #5.
It was 60 psi.
The cyllinder next to it was 140 psi.
It looks like it is a bad valve or broken piston ring on #5.
Is there a way to find out exactly before disassembling?
Any ideas what may the costs be?
Thank you.
Old Jan 15, 2005 | 01:17 PM
CRAZYHAWK's Avatar
Put some oil in sparkplug hole #5. If compression improves it's the rings, otherwise the valves.
Old Jan 15, 2005 | 05:20 PM
maverick007's Avatar
I had misfiring problem with my Audi 1.8T A 4. IT took the dealership a week to figure out what the problem was!! Finally they found Mass Air Flow sensor and O2 sensor's were failing.
cncbamf
May 9, 2017 05:39 PM
googlegot
Jun 10, 2012 06:25 PM
tketke
Nov 4, 2008 12:01 PM
limptimtim
Mar 16, 2007 11:21 PM
nitro_rider2001
Feb 27, 2007 07:39 PM
