A4 Speedo Problems , help please
Thanks for all the quick replies. I will keep checking the wiring. I've already checked the front speed sensors. I heard that these cars also have rear sensors. Is that true?
Thanks!
Thanks!
I was finally able to fix this issue and wanted to share in case anyone else has this problem in the future. Apparently, water can become trapped inside the speed sensor connection (the sending unit attached to the tranny), causing a short. I took the sensor out and gave the sensor connector and the harness connector a good cleaning. I was very happy when I found out this did the trick. Hope this helps someone else.
