A4 sunroof leak
I have a '96 A4 with a sunroof problem. My sunroof drain tubes are sending water out behind the rear wheels, which is fine, but they also leak a lot of water down the B and C pillars into the rear passenger footwell (more than an inch on a really rainy day). Is there a simple solution that doesn't involve removing the headliner?
belive it or not this is actually a common problem. try this link https://www.audiforums.com/m_391895/.../tm.htm#393139 if it doesnt work just look at my previous threads. youll have an answer. and just a tip, do a little research before u ask a question. someone has probably already asked it and you will get burned!!! hope it helps. oh, you could also check www.audiworld.com
Thanks Mr Mudpuppu_94. Unfortunately the link didn't help. I actually did research this for some time and the reason I posted my question was because no-one seemed to mention water VISIBLY running down the B and C pillars. I also rang Audi and their engineers have never heard of it. If they haven't heard of it, it's most definitely not going to be cheap, and so i took my query to the wider world. Thanks though for your help.
ORIGINAL: mudpuppu_94
Try getting a compressor and using that to blow the air through the drain holes.. if you hear a popping sound, thats just it unclogging
ORIGINAL: Redgoat
There wont be any burning for questions like this.. only the questions that get asked over and over again.. i would have to say this is a legit question.
i know that. i was only telling him that i asked this question last week.
anyways i talked to a few guys back when i asked who had the same problem and they said all the did was blow the trash out of the sunroof drain line
