ABS controller swap
Old Jan 12, 2007 | 06:31 PM
Trey25's Avatar
Default ABS controller swap
This salvage yard has a ABS controller for $150 that I'm considering. A new one plus labor is $1500 at the stealership, a rebuilt unit is $250+ so I was thinking I could just buy this used one and replace it. The "catch" is it comes with hydraulic pump also which I don't need. I figure if the part numbers match up then it could just be a simple swap right? Or would I have to recode the controller to the cars ECU in order to clear the code? Anyways this options is cheaper than the others so should I go for it?
Old Jan 12, 2007 | 06:37 PM
techbod's Avatar
Default RE: ABS controller swap
why the change whats the problems??
Old Jan 12, 2007 | 06:43 PM
Trey25's Avatar
The infamous faulty ABS controller. I've been ignoring it for a year but I figured I should get it over with.
Hey Avant whats the part # for a bosch 5.3 from a 98.5 2.8? I got 8E0-998-375-D, well thats what the stealership said, is that right? And is a unit with a different part # compatible?
Old Jan 12, 2007 | 06:49 PM
techbod's Avatar
check the ground wire to the ABS ECUthat's also a known problem
Old Jan 12, 2007 | 06:51 PM
techbod's Avatar
check all the contacts to the ECU use dielectric spray to clean the contacts
Old Jan 13, 2007 | 12:03 AM
BaconBait's Avatar
I did mine by myself in about an hour. The only hard part is reaching some of the screws on the module. There's a great instructional video on the modulemaster site.
Link
The only thing I would add is that you really need to disconnect one of the sensors on the fluid reseviour to really get it out of the way.
I have a 2000 A4 and got a unit from a 2001 S4. No reprogramming. I just disconnected the battery before I disconnected the old one and installed the new one.
Old Jan 13, 2007 | 04:46 AM
Trey25's Avatar
So once you installed it the code automatically cleared, no more ABS light, and there was no need for a VAG? Was it the same part number? It seems like there are a bunch of different part numbers depending on year, but its basically the same bosch 5.3 for all 97+ models.
o0hmikee
Oct 24, 2011 10:19 PM
davey_g78
Feb 10, 2007 03:57 AM
nickt1216
Nov 1, 2006 02:15 AM
impaler2383
May 17, 2006 11:29 PM
