aftermarket head unit with bose system
Old May 9, 2006 | 08:47 PM
Silver98A4's Avatar
Default aftermarket head unit with bose system
I know that it has been touched on before...but who has actually installed an aftermarket head unit with a bose system? Crutchfield does not sell a wiring kit for this system...so would that mean splicing into factory wires? Are there other wiring harnesses available? I am not sure if I want an aftermarket head unit...but I might be interested if the job looks right
Old May 9, 2006 | 08:51 PM
Dstranks's Avatar
Default RE: aftermarket head unit with bose system
I did everything to my sounds system in my 2000 a4 1.8t Q and I had to rewire the entire car because according to tweeter and other car audio places... audis put out a weird ammount of ohms and each speaker has its own mini amp attached to it, thus if you put a headunit in and not new speakers ur old ones will blow.
Old May 9, 2006 | 09:12 PM
Silver98A4's Avatar
that is not really the news i want to hear haha thanks though..
anyone else?
Old May 9, 2006 | 09:16 PM
lbraasch's Avatar
https://www.audiforums.com/m_271105/tm.htm
try scrolling down a bit before starting a thread on almost an identicle topic.
Old May 9, 2006 | 09:31 PM
Silver98A4's Avatar
In being a member here for almost a year, and a member of other car forums for even longer - i can understand the frustration of reading threads that are almost the same. However, unless I am just browsing all of the topics because i have some time to kill...i would not necessarily read a thread called "how the hell to install an amp" when I am interested in the installation of a head unit. I already have an aftermarket amp in my car for my subwoofers, and for that install - I did not have to re-wire the car or touch the headunit even once for that matter.
so even if i did scroll down a bit...which I did because i remember seeing the "how to install an amp" thread...i did not think that it would concern my topic
Old May 9, 2006 | 09:42 PM
lbraasch's Avatar
didn't mean to harsh you out. just didn't wanna type it out agian...
short answer to your question... you're gonna need to run speaker wires regaurdless.
Old May 9, 2006 | 10:00 PM
02A4_B6's Avatar
You will need an adapter to plug onto the factory connector from the dash/wiring harness. You will also need a high level to low level adapter to take speaker level audio down to an isolated low level output. The original Bose stereo has low level outputs on it that go to each amp located at each speaker. In some Bose stereo systems the amps will be supplied with 12 volts which is switched on by the remote power control lead from the Bose stereo. If all possible I wouldn't change or remove the Bose speaker/amp units because they are matched to your vehicle to give you the best sound possible. In the future you can always add another small amp to drive one or two woofers for added bass output! now the only thing left is to check these links out. good luck, be patient.
http://www.audiworld.com/tech/elec128.shtml
http://www.discountcarstereo.com/detail.aspx?ID=440 ........ try searching for something similar to this but made for audi, not sure if u could use this in an audi. someone might sell something a lil more plug n play
Old May 9, 2006 | 10:43 PM
Silver98A4's Avatar
ok so basically this isnt really a great idea....i had a feeling it wouldnt be. I am really content with the sound quality of my bose and my subs, and i have my ipod hard wired into my concert unit now so its all great..
theres just something about the alpine units that make me want to buy one...but i see that its not really that practical for me.
thanks for all the input
Old May 10, 2006 | 03:46 AM
B6er's Avatar
Metra makes a harness for the Symphony and Bose integration. 70-1787 70-1787
For models amplified with Bose:
1996-03 Audi A4 / 1996-03 Audi A6
1997-03 Audi A8 / 2000-01 Audi S4
2002-03 Audi S6 / 2001-03 Audi S8
2000-03 Audi TT
Use the White and Gray RCA’s for the front
speaker output and use the Green and
Purple RCA’s for the rear speaker outputs.
Be sure to connect the Blue/White wire to
the aftermarket radio’s amp turn-on wire.
The White, White/Black, Gray, and Gray/Black
speaker wires will not be used.
For all models with power antennas:
Plug the Blue wire (supplied) in the position
above the Yellow wire. Be sure to connect
the Blue wire to the aftermarket radio’s
antenna turn-on wire.
Old Feb 12, 2021 | 02:16 AM
ThackAttack0311's Avatar
Default B6er
Is that the only thing needed to get the head unit up and goin?
feardafish
Aug 13, 2014 03:03 PM
armedjustice
Sep 27, 2007 05:49 PM
mack29730
Jan 26, 2007 08:42 AM
rrcustom
Apr 4, 2006 02:46 PM
chelskisw6
Nov 11, 2004 08:48 PM
