Aggravating problem
Old Aug 4, 2005 | 03:39 PM
MadIce's Avatar
Default Aggravating problem
I have a very annoying problem that just happened yesterday and it already seems to be getting worse. Last night when I started the car the ignition key hole messed up on me some how. When I start it stays in the starting mode so I have to pull the key back a little bit so the starter doesn’t mess up. And when I go to take the key out I have to force it to turn to the off position to get the key out. Now even though I get the key out, the car seems to stay in the accessory position because everything in the car can still be turned on. So has anyone had any problems with this keyhole?
I want to take the whole thing out, but it looks like the steering wheel has to come off to get the keyhole out...?
Old Aug 4, 2005 | 03:46 PM
CRAZYHAWK's Avatar
Default RE: Aggravating problem
Is the steering wheel locked when you remove the key?
Old Aug 4, 2005 | 03:50 PM
MadIce's Avatar
CRAZYHAWK - I can't remember if it did or not, but.....
Well I guess this is another common problem because I found a write-up on Audiworld, which is the exact problem I have: http://www.audiworld.com/tech/elec91.shtml
Old Dec 5, 2006 | 12:50 AM
fritz's Avatar
has anyone attempted this?
Old Dec 5, 2006 | 12:53 AM
acetrebo's Avatar
Its your lucky day.
This has just been recalled. Read this thread.
https://www.audiforums.com/m_402121/tm.htm
Old Dec 5, 2006 | 12:56 AM
tractioncontrol's Avatar
Yes it is that easy.
pyrobionic
Jan 16, 2014 03:25 PM
Whitson528i
Dec 15, 2013 08:58 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
BryanB
Mar 7, 2009 12:43 PM
