AirBag light is on???any ideas??? 97A41.8SE
Old Nov 13, 2006 | 10:41 AM
ricscars's Avatar
Default AirBag light is on???any ideas??? 97A41.8SE
without any warning my airbag light has come on and now won't go out any ideas?????
Old Nov 13, 2006 | 10:42 AM
Amze's Avatar
Default RE: AirBag light is on???any ideas???
Last thread I read on this the kid took either took the light out that makes it show or covered it up with something.... lmfao.
BECAUSE IGNORING PROBLEMS MAKES THEM CORRECT!!!
Old Nov 13, 2006 | 10:46 AM
ricscars's Avatar
Thanks for your very helpful idea, but do you have any other ideas?? by the way its a 97 A4 1.8 se
Old Nov 13, 2006 | 12:33 PM
AF_guy_ram's Avatar
I recently had my airbag light come on my 97' a4 2.8 and took it to the stealers(dealer). They told me it was an erroniouse(excuse my spelling) fault and they reset it. Its good now. Hope that helps!
Old Nov 13, 2006 | 04:19 PM
JP A4's Avatar
well it was a recall, they do have abad ground in the 97 1.8t i would take it to a dealer and say you want all the recall work done, another thing was if you have an auto, was the valve for the brake booster valve won't operate correctly in -4 degree weather, just take it to the dealer and tell them to fix the ground and hopefully they will reset it
Old Nov 13, 2006 | 05:58 PM
ImTheDevil's Avatar
Default RE: AirBag light is on???any ideas??? 97A41.8SE
The experience with my car was that I put the seat back too far, and it pulled the driver's seat airbag connector somewhat loose, enough that it triggered a fault light. I put the connector solidly back together, zip tied it to keep it in place, and had the fault light cleared - no problem since. From my reading on here, it seems that several others have had the same issue.
Old Nov 13, 2006 | 06:23 PM
david9999's Avatar
Often it is the connector under the passenger side seat. Check to make sure all connections are tight.
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
geoff4
Feb 26, 2006 03:13 PM
