Airbag lights and ABS lights
Old Mar 13, 2007 | 01:02 AM
bluepreludesrv's Avatar
Default Airbag lights and ABS lights
I have an 99 Audi A4 2.8 quattro and for almost a year i had two lights pop up for no reason an airbag light and abs light ive had them rest and scanned a few times but nothing helps. Has anyone experienced this and know what the issue may be?
Old Mar 13, 2007 | 01:56 AM
98A4TQ's Avatar
Default RE: Airbag lights and ABS lights
Im not the smartest man in the world but,, lights generally don't pop on for no reason. Only bit of info I can offer is try to lock up your brakes in the rain if they lock up your ABS control module is probably shot. As far as Air bag light , me personally I would have it checked by a Euro tech.
Old Mar 14, 2007 | 02:21 AM
jfrank's Avatar
Do you have a pre or post facelift 99 (small side marker light vs. large rectangular) if you have a pre facelift (small light) then your airbag computer is shot or the clock spring (located in the column) is bad. the airbag computer is 500 and 200 to install and the clockspring varies. Its not a life threatening situation it just means that your airbags arent functional. My airbag light has been on for a year or so now and its just one of those things I've learned to live with.
Old Mar 14, 2007 | 05:07 PM
khaoswing's Avatar
damn I have the same problem..my is 1998 2.8 l....so how can you go about trying to erase the light???
or do you have to replace the stupid airbag computer???
Old Mar 14, 2007 | 06:42 PM
klum00's Avatar
stupid airbag computer, gosh!
Old Mar 14, 2007 | 07:10 PM
techbod's Avatar
ORIGINAL: khaoswing
you have to have it scanned for fault codes because the airbag and ABS lights are on constantly ( which means they are disabled ) or switched off to you
jfrank's Avatar
your trusty mechanic can reset the light but it usually resets in a few hours. chances are youre gonna need a computer or clockspring... Or just learn to live with it like I have
nize
Jun 21, 2013 01:16 PM
archangel1st
Nov 9, 2010 09:04 PM
Jackmup
Oct 4, 2009 09:05 PM
Capo Cam
Nov 18, 2008 05:28 PM
mizzike2555
May 30, 2007 09:17 AM
