all problems solved misfire codes
Old Mar 12, 2007 | 11:35 PM
breeze.12's Avatar
Default all problems solved misfire codes
2000 a4 quattro 1.8t had misfire codes 300 301 302 and sometimes 303&304 drivin me nuts, would spit and cough when cold and be in limp mode warm. changed coil packs, no different. also had a previous 1128 codecouldnt find any vaccum leaks. AHHH!! when I unplugged maf after reading a post, car ran almost perfect except for a slight miss at idle. after changing maf all is perfect.
Also, oil light is flashing occasionally. put an analog guage on it and after normal operating temp is reached, oil pressure is 12psi at idle and 60psi at about 2500rpm`sthat sound about right? I am suspecting the oil pressure sensor. hope this helps someone.
Old Mar 13, 2007 | 01:20 AM
acetrebo's Avatar
Default RE: all problems solved misfire codes
You may want to check a bently/haynes to make sure, but it sounds about right.
Old Mar 13, 2007 | 01:54 AM
breeze.12's Avatar
thanks, hopefully its in specs, Id rather change a sensor than an oil pump
Old Mar 13, 2007 | 02:06 AM
acetrebo's Avatar
Was you oil full?
What oil do you use?
Old Mar 13, 2007 | 02:18 AM
breeze.12's Avatar
yes, mobile 0-40 synthetic
oldrallyfan
Jan 30, 2013 09:52 AM
A6-Lou
Mar 6, 2012 06:06 PM
heysailor
Nov 4, 2007 10:43 AM
AndyMann1966
Jul 10, 2006 07:40 AM
oleafo
Jun 26, 2006 02:42 PM
