Misfire Troubleshooting-Help-Solved!!!!
Old Nov 3, 2007 | 09:24 PM
heysailor's Avatar
Default Misfire Troubleshooting-Help-Solved!!!!
I have researched this topic but have been unable to solve my problem. I have a 2001 A4 1.8T(AWM engine code). I'm getting a flashing CEL and codes P300/301/302/303/304. The car is really not drivable due to the severe misfires. I replaced all 4 coil packs and spark plugs-no change, same codes. What else should I be checking here without throwing money at new parts?
Old Nov 4, 2007 | 07:19 AM
dankhound's Avatar
Default RE: Misfire Troubleshooting-Help
Check your fuel. You may have bad gas. You didnt use E85 did you?
Old Nov 4, 2007 | 10:02 AM
heysailor's Avatar
I didn't fill up with E85, and the misfires don't correlate with a fuel fill up. I do know that the MAF needs to be replaced(its on backorder) but the guys at ECS Tuning say this shouldn't cause misfire. Your thoughts? Could this be a fuel delivery problem(clogged fuel filter, gummed up injectors, etc.) causing the misfires? The engine idles fine and smooth. I have confirmed that each coil is supplying a spark (at idle) but when the engine is under heavy acceleration it misfires voilently.
Old Nov 4, 2007 | 10:43 AM
heysailor's Avatar
Default RE: Misfire Troubleshooting-Help-Solved!!!
Just thought I would update this thread. I disconnected the MAF and this eliminated the misfires. I suppose the MAF was supplying really-really bad data and the baseline setttings are sufficient to allow then engine to run OK. New part is on order.
kpatz
Jul 14, 2015 11:19 PM
A6-Lou
Mar 6, 2012 06:06 PM
BrockSamson
May 29, 2010 06:40 PM
a2thy
Jun 30, 2009 06:08 AM
breeze.12
Mar 13, 2007 02:18 AM
