Alternator?
Old Nov 10, 2007 | 02:30 PM
onepoint8tee's Avatar
Default Alternator?
To anyone whos removed the alternator on a 97-00 1.8t
I have the top and bottom bolts out, and it swivels from side to side about an inch. What is keeping it in place? I cant slide it out with any amount of force, unless I need to use a breaker bar, in which case Id hate to think would it would be like getting it back on...??? Anyone?
I have to get the alt out to get to the water pump to replace.
Old Nov 10, 2007 | 02:36 PM
auditech79's Avatar
Default RE: Alternator?
I PM'ed you but did you get the lower bolt out that the alternator swivels on? You have to get the fan out of the way because the bolt is huge! If you did get it out you may need a pry bar to get it out, its a really tight fit.
Old Nov 10, 2007 | 02:39 PM
ORIGINAL: auditech79
Nevermind, I just got it. Yes I removed the fan/clutch pulley to get the lower altbolt out. Thanks.
Old Nov 10, 2007 | 02:42 PM
auditech79's Avatar
[8D][8D][8D]Nothing a little elbow grease couldn't fix eh?
Old Nov 10, 2007 | 04:57 PM
Damn... What a pita.... Finally the pump is in and most everything is hooked back up except for the lock carrier. That alternator/water pump mounting configuration is a POS. Whatever, Ill have to finish tomorrow cuz my wife decided to throw a party.
Old Nov 10, 2007 | 05:00 PM
auditech79's Avatar
Thats why they changed it to timing belt driven.
MattSCESC
Jan 12, 2012 04:21 PM
kduznetsov
May 3, 2011 08:14 AM
phosphateb
B7 Models
Nov 3, 2009 08:44 PM
BigMac421
Sep 23, 2009 08:52 AM
jeremyty
Aug 31, 2009 09:28 PM
