Anyone else get this noise?
Old Mar 9, 2007 | 06:21 PM
jstehle's Avatar
Default Anyone else get this noise?
Hello when driving around the city streets I get this noise in side the car. It is coming from the rear. I cant quite figure it out. I get out of the car and push on the trunk and work on the suspension and hear nothing. Today I sat in the back seat and bounce up and down, it sound like the gas in the gas tank was making all of this noise. Does anyone else have this or an opinion on what the noise good possible be. I wouldnt think that gas moving around would make this noise. Any help would be good. The car is a 1996 Audi A4, thanks
Old Mar 9, 2007 | 06:36 PM
techbod's Avatar
Default RE: Anyone else get this noise?
could be the fuel pump or the filter but mine does that and not a problem because its a V8 so its the sump pump which is normal on big engines to keep the fuel moving because they need it more than the 4 bangers for smoooooth driving
Old Mar 9, 2007 | 06:41 PM
new2me's Avatar
Mine makes a gurgling sound when i start it and has a constant whine but the gurgle goes away after a few minute.
Old Mar 9, 2007 | 06:42 PM
Audi_Skydiver's Avatar
ORIGINAL: new2me
So does mine. Is that normaL???
Josh
Old Mar 9, 2007 | 07:13 PM
new2me's Avatar
Yea as far as im concerned.
I prity sure its just the pump priming. I have not noticed any problems with it and im running 15-20psi (depending what gear)
Old Mar 9, 2007 | 08:54 PM
Trey25's Avatar
Its the fuel pump, should be normal. If its excessively loud then its probably on its way out.
Old Mar 9, 2007 | 09:02 PM
onepoint8tee's Avatar
My fuel pump is silent from inside the car. Could be a failing pump.. They can be noisy for a long time before they finally fail. Doesnt mean its not doing its job though.
Old Jun 4, 2007 | 12:30 PM
Leon78's Avatar
Try to look at thread - wierd noise from the fuel tank???!!
We have the same problem.
rahip4567
B8 Models
Nov 13, 2019 04:04 AM
kenman
Sep 12, 2012 02:34 PM
Schlampah
Jan 27, 2011 08:24 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
