Apr Stg 3+ or GT28 custom
ORIGINAL: cincyTT
all you have to do is add in a cat. You can either have your stock cat made to fit (maybe $30-40) of add in a 3" universal cat ($100-150 for the cat, and $30 for exhaust sleeves and clamps so you can easily swap in the cat and testpipe)
the only one is a eliminator turbo. But you might aswell spend the couple extra hundred $$ for a dp since the t25/t3 housings flow so much better and make tons more power.
ORIGINAL: cincyTT
then get an o2 spacer and call it a day. Its really not to hard.
Did anyone say you were? But you need two spacers from what i have seen to work. My ebay dp puts the o2 sensor where i couldnt fit even one to use them so i just stare at a cel.
FYI.. I have an APR stage 3 AEB A4 and I put almost 20k on the car within a year, kit now has about 65k on it total and I never had one engine/turbo problem ever. I finally am going bigger, probably a gt3071r, with the APR mani.... but the GT28R turbo is rock solid and a great choice for someon going from a KO4 or stock.. globs of power, quick spool up and boos that holds until redline, ~23 psi
josh
josh
