Apr Stg 3+ or GT28 custom
Old Nov 2, 2007 | 06:41 PM
cincyTT's Avatar
I'm make believe
Default RE: Apr Stg 3+ or GT28 custom
then get an o2 spacer and call it a day. Its really not to hard.
Old Nov 2, 2007 | 08:10 PM
turbo kraut's Avatar
Tech Guru
i know........and i wasn't trying to argue...... i am always trying to learn
Old Nov 3, 2007 | 11:47 AM
cincyTT's Avatar
I'm make believe
even with the code written it, i believe the code is still stored in the ecu.
Old Nov 3, 2007 | 12:01 PM
Bogie's Avatar
ORIGINAL: cincyTT
all you have to do is add in a cat. You can either have your stock cat made to fit (maybe $30-40) of add in a 3" universal cat ($100-150 for the cat, and $30 for exhaust sleeves and clamps so you can easily swap in the cat and testpipe)
So with GT2871r won'tbolt up tothe stock cat in the stock location?If not, whataftermarket turbo (that puts out more powerthan aKO4) willbolt right upto the stock cat in the stock location.
Old Nov 3, 2007 | 12:17 PM
cincyTT's Avatar
I'm make believe
the only one is a eliminator turbo. But you might aswell spend the couple extra hundred $$ for a dp since the t25/t3 housings flow so much better and make tons more power.
Old Nov 3, 2007 | 12:21 PM
Bogie's Avatar
guess i'll search for a high-flow cat that will bolt up to the t25/t3 housing and fit right up tothe cat-backexhaust i have now...any recommendations off hand cincy?
Old Nov 3, 2007 | 12:40 PM
cincyTT's Avatar
I'm make believe
nothing is going to bolt to a t25 or t3 housing. You just need to do what i said above.
Old Nov 3, 2007 | 07:37 PM
  #18
Kyle09's Avatar
ORIGINAL: cincyTT
Those dont work, i have one, and yes I installed it right, im not a dumbass..And still CEL, I have a b6 though, i dont know about b5's.
Old Nov 3, 2007 | 08:02 PM
  #19
cincyTT's Avatar
I'm make believe
Did anyone say you were? But you need two spacers from what i have seen to work. My ebay dp puts the o2 sensor where i couldnt fit even one to use them so i just stare at a cel.
Old Nov 4, 2007 | 10:04 AM
  #20
Beemer832's Avatar
FYI.. I have an APR stage 3 AEB A4 and I put almost 20k on the car within a year, kit now has about 65k on it total and I never had one engine/turbo problem ever. I finally am going bigger, probably a gt3071r, with the APR mani.... but the GT28R turbo is rock solid and a great choice for someon going from a KO4 or stock.. globs of power, quick spool up and boos that holds until redline, ~23 psi
josh
