ATF change, need info and help
Old Feb 13, 2005 | 09:30 PM
Dr_Vitez's Avatar
Default ATF change, need info and help
Need help about oil (ATF) changing in automatic getribe.
What temp must be engine, temp of atf, car is on or off, ....
some pictures about holes for filling andcontrol oil.
Never do that and becaouse this need help.
SO in need full procedure.
Regards
Old Feb 13, 2005 | 11:24 PM
Doose's Avatar
Default RE: ATF change, need info and help
Do you have a VAG-com? You really need to have one for this job.
Old Feb 13, 2005 | 11:27 PM
david9999's Avatar
It is probably easier to just take it to a garage that specializes in Vw/Audis. The labor charge should be about 30-45 minutes.
At 40 degrees C, the fluid should just start dripping out, or alternatively, at this temperature, with the engine idling in park.
Old Feb 14, 2005 | 11:51 AM
Dr_Vitez's Avatar
Yes i have VAGCOM,
and about oil and 40C, this could be temp of atf in car, but hov to see what temp of atf is in car becaouse old oil is pumped out.
I realy need whole procedure from droping old oil to fill new oil to car.
Regards
Old Feb 14, 2005 | 12:05 PM
Jestnomen's Avatar
6th Gear
My mechanic just tapped into the atf cooler lines and drained it from there and refilled it from the return line. Havn't had a problem in 20k miles.
Old Feb 14, 2005 | 02:33 PM
brrman's Avatar
VW dealer will do it for about $125 (incl fluid)
The ATF temp will rise and then stay steady. Once this happens you can drain the fluid with the drain plug, and then use a fluid pump to fill to the top of the lip on the fill hole.
Old Feb 14, 2005 | 11:27 PM
david9999's Avatar
agree
Old Feb 15, 2005 | 10:07 PM
blades's Avatar
Member
Isn't there an internal filter in the trans that should be changed?
Bagheera223
S4
Mar 17, 2015 11:10 AM
mmdambro
Dec 16, 2010 12:23 PM
bjp1
Apr 26, 2010 09:49 AM
jjuzwik
Nov 16, 2007 06:37 PM
prashantsp
Sep 15, 2006 12:48 AM
