audi a4 blower fan problem
Old Nov 10, 2006 | 03:14 AM
preyash's Avatar
Default audi a4 blower fan problem
In my 1996 a4, when i turn the ac/heater fan on more than 2 bars in speed it make this weird noise, something like the fan touching some plastic, so i have to always keep it on 2 bars and cant increase the fan speed because of that annoying noise, is there anyway i can diagnose this problem myself, I assume its the blower fan blades touching the plastic and it prolly misaligned, what do u guys think
input will be greatly appreciated.
thanks
preyash
Old Nov 10, 2006 | 07:32 AM
techbod's Avatar
Default RE: Audi a4 blower fan problem
just sorted mine yesterday with same problem I had to remove the wipers/ plastic cover below the windshield and cabin filter to get at the fan ( there was a lot of derby in there dust/ leaves/ bits of old cabin filter ) now running silent, my problem was the motor only had 1 speed and that was fast[:@] very noisy and problem was a blown resistor pack because the fan was sticking at low speed.
I replaced the resistor pack at £32 + VAT ( greedy sods ) and it blew again next fix was easy because I found out it was only a heat sink that blew 75 pence at Maplin electronics,
next time anyone fan only blows air at one speed change the heat sink before you waste money on a complete unit ( don't solder it in because the heat from the solder will blow it ) just crimp the wires in place - the A4 resistor pack is a whelping £60 + VAT when all you need is a 75 pence heat sink so its worth remembering this in the future and not just for the A4 its for all cars
Old Aug 16, 2010 | 08:49 AM
JB5's Avatar
JB5
does anyone know where this resistor is? im having the exact same issue.
Old Aug 29, 2010 | 07:20 PM
CrazyA4's Avatar
Thumbs up A4 blower fan makes noise when turned up above 2 bars
I found my old A4 car fan to have a couple of blades cracked and the plastic tunnel in front of the fan was black burnts where it was touching/rubbing the fan spinning......when I finally removed it after removing the glove box! Basically the blades moved out of place the faster the fan went! UK car
main problem before removing it was there were a couple of bolts holding in the passinger air bag that had to be removed to get to it.
Simple 3 philps heads holding it in place.
hold new fan in place and test before fully fitting. £35-£40 from breaker yard
I ended up cutting away some of the plastic tunneling before fitting the new fan but this cut the performance of the air a little.
I hope this helps
Old Sep 13, 2010 | 01:02 AM
mikeross's Avatar
Member
I have the same issue.. What audi a4 parts do I need to replace? Thanks. The mechanic told me that the fan needed replacement. But after he replaced it, the same thing occurs.
Old Sep 25, 2010 | 05:33 PM
CrazyA4's Avatar
Might not be the same issue then (?) though the 1st time I fitted mine with new fan, the fan still made a noise i had no problems when holding the new one in place to test but after the 3 screws were tighen the problem happened again.hence why i had to cut some of the pipe inside where it fits into.
Old Jan 3, 2011 | 10:09 PM
sjmsmart's Avatar
Hi
I have the blower speed problem on my Audi A3 1996, can you help me and tell me what a heat sink is, and where it is located, I have no idea how to locate/access the fan resistor but am pretty good at these things so was going to buy one together with a haynes manual to fix but like you say they are over £30.
Any help would be appreciated.
Thanks
Simon
daboss085
Dec 10, 2012 06:26 PM
Euge82
May 18, 2012 10:31 AM
Flannigan13
Jan 24, 2010 11:38 PM
MikeInMexico
Nov 14, 2008 08:37 PM
jimUK_2
Feb 11, 2007 03:14 AM
