Audi A4 indicator failure
Old Jan 5, 2006 | 10:43 AM
az's Avatar
az
Default Audi A4 indicator failure
I have an Audi A4 2.8SE. All 4 indicator lights have stopped working and the indicator lights on the dashboard do not work. Fuses are OK - what else should I check?
Also. the main display shows error messages - I suspect there is a fault in the ABS module because when I physically move the connectors the errors disappear - has anyone else had a problem like this?
Old Jan 5, 2006 | 09:38 PM
John_E's Avatar
Default RE: Audi A4 indicator failure
Check those fuses with an ohm meter.
If wiggling a wire makes a problem come and go, clean the relevant contacts and inspect the wires and connections for cold solder joints.
Old Jan 9, 2006 | 08:36 AM
az's Avatar
az
I found the fault - it was a faulty hazard lights warning switch - replaced it and the indicators are now working
Robert Thomson
Nov 28, 2012 05:17 PM
suffolk
May 12, 2011 04:36 AM
SVT21
Apr 2, 2008 08:52 AM
TPE_A3
Dec 16, 2007 01:19 AM
Gaz80
Mar 23, 2005 12:04 PM
