b5 5 spd tranny fluid change
Old Nov 1, 2005 | 10:31 PM
jja2.8's Avatar
Default RE: b5 5 spd tranny fluid change
from searching around i think i found the answer to my question. gl5 or gl4?
apparently gl5 is not to be used in the gearbox, it can damage the brass synros. use gl4 instead.
bentley manual says to use G 005 000
Old Nov 2, 2005 | 05:39 AM
sandman's Avatar
ORIGINAL: david9999
One word of advice. Always open the fill plug first.
If you drain your transmission or differential, and find your fill plug is frozen in place,[:@], you are going to have to tow your car to a grage.
yea defanetley a good idea, it will also help the fluid drain faster, its like shotguning a beer you know?
Old Aug 5, 2007 | 01:26 PM
audi_bos's Avatar
Great guide! Is this the same porcedure for a 97 A4 2.8 5spd? Am I going to need the 16mm XZN tool? I have not went under yet to inspect, just thaught I would ask first. Also is Mobile 1 75W-90 the prefered oil?
Butternuts
Apr 5, 2008 07:13 PM
JaceTun
Mar 15, 2008 12:01 PM
onepoint8tee
Jan 31, 2006 08:09 PM
dougdanger
Dec 31, 2005 06:58 AM
