Bad Turbo Or What?
Old Oct 23, 2006 | 12:42 AM
kraylon's Avatar
Default RE: Bad Turbo Or What?
yep thats it take off the rubber hose that goes to it and check it and also check that turbo inlet hose and yes it has a diapham but if the diapham was bad it wounldn't cause a boost leak it would let oil in the turbo inlet hose
Old Oct 23, 2006 | 12:52 AM
AudiTurbo's Avatar
There was oil in it, because i took it off the other day to change the n75 valve and there was oil in it.....are you sure that wouldnt have anything to do with the no boosting problem?
Old Oct 23, 2006 | 01:05 AM
Lazer Viking's Avatar
a reasonable amout of oil in it is fine, just as long as you didnt take it off and have to pour the oil out...then you might have a problem
Old Oct 23, 2006 | 01:08 AM
AudiTurbo's Avatar
there was a good amount of oil in it, but not a huge amount.... i was able to sit it on the side and the oil would drain out of it.
Old Oct 23, 2006 | 01:14 AM
i think that may be excessive, i know there is an oil coating on the inside of pretty much the entire intake system, just from normal running... i think that you may have too much for some reason, you didnt overfill the oil did you ?... just start the motor take off the turbo inlet pipe and cram a screwdrive in there...that was you have a reason to go k04 haha, but yea i dont know what else would cause excessive oil like that
Old Oct 23, 2006 | 01:19 AM
AudiTurbo's Avatar
would that cause me not to boost much at all?
i have the giac ecu and im running like 2psi and i should be at about 14.7 or more.....i was going to get a new turbo, but i dont know if that would solve everything.....
Old Oct 23, 2006 | 01:22 AM
to me it sounds like more of a leak then a bad turbo... if it were a bad turbo it would have like fading boost or would boost at all, or would sound like hell when it spooled, if its a leak then its something that would be letting that oil in, im not sure if the crankcase vents into the intake or not...but if it does then i would start there... if its anything on the turbo i would say your wastegate is probably shot
Old Oct 23, 2006 | 01:31 AM
  #18
AudiTurbo's Avatar
where should i look for the leak?
could that pancake vavle have something to do with it though?
Old Oct 23, 2006 | 01:35 AM
  #19
AudiTurbo's Avatar
i took the bottom intercooler pipe off also, and there was oil in the pipe...
Old Oct 23, 2006 | 01:40 AM
  #20
the pancake valve itself dosent have anything to do with your low boosting...actually i really dont know what purpous that thing serves, and if that had oil in it i would expect the inlet tube to aswell.. was there oil in it when you took it off before ?
