Bad Turbo Or What?
Old Oct 23, 2006 | 04:20 PM
  #31
AudiTurbo's Avatar
Default RE: Bad Turbo Or What?
OK...i get a new hose today, and while im out getting that i will take the negative cable...
Old Oct 23, 2006 | 04:25 PM
  #32
AudiTurbo's Avatar
I also just replaced my stock N75 valve with I think a N75j valve.....im not for sure....its brown and my buddy gave it to me..
Old Oct 23, 2006 | 04:30 PM
  #33
The Bishop's Avatar
That shouldn't affect it (at least not enough to make it run at 2 psi) unless your ecu is messed up.
Old Oct 23, 2006 | 04:34 PM
  #34
AudiTurbo's Avatar
I just got it back from giac.....the reason i sent it is because i thought the car was just big and heavy(didnt know that it wasnt boosting until i got it back and put the boost gauge in...
Old Oct 23, 2006 | 04:38 PM
  #35
The Bishop's Avatar
I would almost be willing to bet money on the DV vac line. I had what sounds like the exact same problem as you. The vac line was the problem.
Old Oct 23, 2006 | 04:45 PM
  #36
AudiTurbo's Avatar
OK.....i just changed the dv valve the other day, so i will go pull it off today.....it is the one that goes to the vac side of the dv valve to the front of the motor(intake manifold..)?
Old Oct 23, 2006 | 04:52 PM
  #37
The Bishop's Avatar
yup, it's that little one.
Old Oct 24, 2006 | 12:31 AM
  #38
AudiTurbo's Avatar
When i was taking off my dv vac line there was a little bit of oil around it.....is that bad??
Old Oct 25, 2006 | 01:39 PM
  #39
The Bishop's Avatar
Did anything work? did you get it fixed? let us know what happened.
Old Oct 25, 2006 | 02:05 PM
  #40
onepoint8tee's Avatar
The vac line from the dv goes up and in front of the valve/timing belt cover and underneath the intake manifold and connects to a T fitting right by the oil dipstick, its not the vac line on the very front/top of the intake mani. Sorta hard to slide the vac line from the dv into the t fitting, i used rolled up index cards taped together to feed the line through/under the intake mani onto the T fitting by the dipstick.
