Battery Replacemennt
Old Nov 17, 2007 | 05:36 PM
drs's Avatar
drs
Default Battery Replacemennt
Icould use some help. I just replaced the battery in the wife's 2003 A4 3.0 Quattro. Started car and ESP(Yellow Triangle) light remains on. Tried turning steering wheel lock to lock, which turns light off on X5s after battery is disconnected. How do I get the light to turn off on the A4?
Thanks,
drs
Old Nov 17, 2007 | 05:53 PM
onepoint8tee's Avatar
Default RE: Battery Replacemennt
ORIGINAL: drs
Makes no sense........? Please rephrase.
Old Nov 17, 2007 | 06:52 PM
drs's Avatar
drs
Replaced battery in 2003 A4 3.0 Quattro. Since battery replacement, the ESP(yellow triangle) light on dashboard stays on when car is running. How do I turn it off?
Thanks, drs
Old Nov 17, 2007 | 06:58 PM
FASTER's Avatar
Tech Slut
ORIGINAL: onepoint8tee
ORIGINAL: drs
makes perfect sense. apparently you can turn the warning light off in BMW X5's by rotating the wheel from all the way clockwise to all the way counter clockwise.
drs: is there a switch for the esp somewhere on the dash or console, if there is, then hit it... otherwise someone else needs to help you, i dont agree with traction control on all wheel drive cars.
Old Nov 17, 2007 | 07:05 PM
hiwords's Avatar
i believe that's a vag com thing
Old Nov 17, 2007 | 08:27 PM
ESP relates to the DBW system. DBW system components are everything between the gas pedal and throtle body. Id try a throtle body alignment since you are supposed to do one after the battery has been disconnected anyways.
Old Nov 18, 2007 | 11:00 AM
dankhound's Avatar
Thats EPC.
Drive the car and the triangluar esp warning light will go off. Otherwise there is a problem witht he system.
Old Nov 18, 2007 | 11:05 AM
techbod's Avatar
^ agree the system needs to relearn but if it stays on it might need VAG to reset it or disclose the fault code
Old Nov 18, 2007 | 12:36 PM
ORIGINAL: dankhound
Thats EPC.
Rofl. Thanks for the correction.
