The Best Airbox Mod? writeup with pics..
ORIGINAL: smokeU
Ok so can someone tell me if the below PRO's and CON's list is correct?
PROS: better throttle response high end, louder turbo, DV sound, better intake sound (growl).
CONS: less pull on the low end, risk of moisture, cutting holes in things, heat soak.
please add to or take away from the list as necessary.
been 5 months with this mod and i have no problems at all. Still love the sound. + tunnels are great. for the cons i can say i have had heat soak. Just have to get a fmic. Heat soak happens w/ or w/out this mod. hydro lock i am not even worried. this mod is cool in my book
ORIGINAL: xbrian87
What is heat soak? Sorry for being a nub.
Heat soak affects your performance like how a wet wash cloth dries your face.
^^^ hahah nice anology!
onepoint8tee: would you recommend drilling holes in the drivers side wheel well to vent the intercooler? I know this is controversial. i think the TT or S4 has it would it help the intercooler at all?
ORIGINAL: smokeU
you know how the lower grill on the IC side has that black plastic intake ram that I'm guessing brings air to the IC? could you do something like that to the other side to bring cold air into the turbo side of the engine bay for intakes and/or cool off the turbo a little?
ORIGINAL: smokeU
forget the mod and fit a K&N panel filter then expand the air intake scoop on the front of the car ( cold air is best from the front of the car ) be damned if you do or damned if you don't
all is worth a try
all is worth a try
ORIGINAL: avant80@2.6
all is worth a try
all is worth a try
