big clutch problem...NEED HELP
Old Mar 15, 2006 | 06:59 PM
OriginalG's Avatar
Default big clutch problem...NEED HELP
i have a 99.5 audi a4 1.8t...and when i got the clutch it wus done fried up....so i got a new one and after like 2 weeeks the clutch is extremely high and isnt slowing down....and i drive standard well so it aint me cuz ive even got 3 mechanics to test drive wit me and they say im not the problem....so i wus wonderin if anyone knew why my clutch is wearin out or the friction point is jus gettin higher and higher for no reason...thank u
Old Mar 15, 2006 | 09:17 PM
hoonee46's Avatar
Default RE: big clutch problem...NEED HELP
I would suspect the guys that installed the new clutch... did they replace the pressure plate? Did you do the flywheel as well while your tranny was dropped? My friend had a similar problem, where he got a brand new clutch, and it would sometimes slip, even with it fully engaged... Because he was specifically told that this would be replaced, he was compensated for the diagnosing fee from a different shop, and the pressure plate was replaced 'free of charge' (he already paid for it to be done in the first place). In my opinion, he should have gotten all his documents together and sued them for malpractice and for the time(money) he wasted....
If your pressure plate is bad, your clutch will slip. Even if it doesn't seem like it is while you're coasting, it still may be letting in little by little, which would explain the rapid wear.... I'm no expert, but that's what it COULD be.... Take it back to where you got it from, and they should take responsibility IMO... Good luck to you
ikkezelf
Jan 31, 2008 06:54 AM
beetee
Jun 1, 2007 06:18 AM
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
dane
Mar 3, 2005 07:25 PM
