Blow Out.........
Old May 18, 2006 | 11:51 AM
Bantanic's Avatar
Default Blow Out.........
Hi Guys!!!!
Test Day yesterday, and on my way to my 13:00 appointment, i come to a spot called "brockerbeck" a very long straight down hill section that tapers for a bridge at the bottom then back up a long straightthe other side, that you can hit at great speeds..[8D]
But as i hit the bottom of this bridge ( just steady away cos it was test day) my engine management light came on and then a bang, then a "pop! pop! pop! pop! pop!"[&:][:@][]
First thought Timing belt...... But no what it was was a spark plug had poped out, the threads weren't damaged that much so managed to get it back in with the trusty SCREWFIX socket set....
She flew thru the test and seems to be OK... (Good Girl)
could this have been just one of them things or is she hiding a greater problem.........Any ideas....[&:]
Old May 18, 2006 | 01:03 PM
Russ03A4's Avatar
Default RE: Blow Out.........
Wow! Never heard of that happening before!
I believe that the "head" is Aluminum and the plug body is steel. If the threads have been damaged it would be on the head which is a much more serious issue. You need to have someone check the "minor diameter" on the thread pitch (on the head) and check that for damage.
Old May 18, 2006 | 01:06 PM
onepoint8tee's Avatar
Strange... I have heard of this before from someone on here... Im sure theyll speak up when they see this... I think he had the kind of coil packs that sort of pop in and are screwed down... maybe that design has something to do with it, if thats the kind you have.
Old May 18, 2006 | 04:05 PM
Bantanic's Avatar
Well the coil and plug all shot off, the only thing that kept it under the bonnet was the plastic cover over the bloc..
hope that it's not damaged the head.........[&:]
Old May 18, 2006 | 04:13 PM
techbod's Avatar
its a maintenance issue that many forget ( engine vibrates things come lose ) it might be wise to remember this on your next service
Old May 18, 2006 | 04:20 PM
kpatz's Avatar
Well, if you are fortunate the plug was not tightened down when it was installed and it just worked its way loose. If you're less fortunate then the threads in the head are stripped and the plug may pop out again.
AFAIK there's an insert that can be put in to repair stripped threads. Basically they drill the hole bigger and then put a self tapping insert in that has a new threaded hole for the plug, then the plug is screwed into that. So it isn't the end of the world even if it is stripped.
Old May 18, 2006 | 04:23 PM
Bantanic's Avatar
Oh yer think that's called hellycoil in't it...................
Well fingers crossed it'll be ok
Thanks guys.......
RyanCox21
Apr 11, 2011 12:51 AM
blackedoutaudi
12
Mar 23, 2010 11:46 AM
1.8TK3MP
Feb 14, 2008 08:24 PM
barqs86
Sep 18, 2006 02:02 AM
rowingdude
Jan 23, 2006 05:40 PM
