Brake fluid and heat tape
Old Jul 16, 2004 | 03:50 PM
A4climb's Avatar
Default Brake fluid and heat tape
(former uomoa4)
No intention to clutter the forums with too many topics, but the questions are different from the previous ones.
Brake fluid. It's a bit low in my A4 1.8, any particular tip ? Better change it all? Or just fill it up?
Heat resistant tape.
I had a little opening in the air duct coming from the upper front grille, before the flexible part that attaches to the air filter. I closed the little gap with DUCT TAPE. Do you guys know a better HEAT RESISTANT tape? / Do you have a better idea for fixing the problem? (Other than ordering a new part)
Thanks!
Old Jul 16, 2004 | 09:36 PM
Doose's Avatar
Default RE: Brake fluid and heat tape
Brakes are not really my forte, but I'd check and see why it's low. Have you had a pad and rotor change lately? Do you notice any change in your brakes at all? There is brake fluid that resists heat better and therefore does not scortch at as low a temp, but I'm not sure that for our application that really has much value. As for the heat tape, yes, there is fiberglass heat tape often used to wrap exhaust pipes that you could use. You should be able to find it at most parts stores. It's a lot like casting material used for broken limbs.
Old Jul 16, 2004 | 10:11 PM
CRAZYHAWK's Avatar
Brake fluid will be lowered as pads wear. Add on a dry day.
Old Jul 16, 2004 | 11:15 PM
A4climb's Avatar
Greast. Thanks guys
B5 Audi
Nov 27, 2009 05:24 PM
AR15Texan
Jun 10, 2009 12:24 PM
jakej
Nov 12, 2008 08:55 PM
orta02
Jan 19, 2006 11:34 AM
